Cedar bathroom vanity Topcoat
2/10/16
Robert Member
Hi all, I have a client who is asking me to build a vanity for his bathroom. There is a small cedar sauna at the other end of the room so he asked if we can build the vanity out of the same material.
I'm wondering what a suitable topcoat might be. I know normally you'd want a high build finish in a wet environment, but wasn't sure if that changes when using a moisture resistant material like cedar. I was thinking of just spraying it with a clear conversion varnish, something like ML Campbell Duravar, which I have leftover from another job. Would that be appropriate?
The vanity will have a Corian sink mounted atop it.
2/11/16       #2: Cedar bathroom vanity Topcoat ...
nick
When it comes to solid wood tops that support a sink, I apply a coat of clear penetrating epoxy sealer (cpes) to all 6 sides first (this really keeps the moisture from getting into the wood) then I usually top coat with CV but sometimes I use Rudds single component polyurethane Prothane...I've had problem free results both ways...that said, my guess would be a 2k poly top coat would be the most durable choice.
