2K urethane high gloss process
3/9/16
dub
I have a project coming up that is high gloss white. Usually customers bail on gloss when I tell them the cost, so I’ve only done smaller projects with production lacquer.
I’ve made samples and have found a process (materials from Sherwin Williams) that provides good results, but thought I would post to get any feedback or tips.
Here is my process:
-color coat (catalyzed Sherwin Williams vinyl sealer)
-Level finish with 220- 360
-2nd color coat if needed. , scuff with maroon pad.
-2K urethane sealer
-Scuff with 360 grit
-2K urethane gloss tack coat, then full wet coat
-Sand with DA 1200 grit with vac
-Sand with DA mirka abralon 2000 grit wet
-Sand with DA mirka abralon 4000 grit wet
-Then move to buffing wheel and through that sequence.
I’m unsure how much I need to level the 2K sealer . Just denib, or full sanding? Any tips?
thanks,
dub
3/10/16       #2: 2K urethane high gloss process ...
chris
i would skip the vinyl and use a white urethane sealer.
is this going to be full filled if so you can use a white polyester sealer
3/10/16       #3: 2K urethane high gloss process ...
kevin
we do tons of high gloss paneling. some times its stain and sometimes its solid color.
when doing stain we follow this schedule:
1. Sand 150 on heeseman widebelt sander to get panels dead flat.
2. Spray dye stain to match sample
3. Seal with sayerlack xr4027 barrier coat
4. Seal with Sayerlack PU317 high solids polyurethane sealer
5. sand flat in heeseman widebelt with 320
6. topcoat with sherwin williams v84v80
We have no need to wetsand and buff with this procedure, as we keep our spray booth extra clean when dealing with high gloss. this yields pristine full filled paneling.
If we are doing solid colors, we follow this schedule:
1. Sand 150 in heeseman
2. Prime with sherwin williams e63W50 primer surfacer
3. Sand 220 in heeseman
4. Prime/Sand again if necessary
5. Spray custom color blended in sherwin williams H66 pigmented conversion varnish
6. Scuff 320
7. Topcoat with sherwin williams V84V80
Again, this yields great results.
3/11/16       #4: 2K urethane high gloss process ...
Shane
Spot on kevin..... we are running pretty much the same sequence and coatings and also have a very fine 52" Heeseman
3/16/16       #5: 2K urethane high gloss process ...
Joe
I've done both..... off the gun as well as wet sand with abrasive progression up to buff. Even in a dust free environment there's a huge difference in appearance with the end result.
