Best Scale for Color Matching
3/15/16
Jason
Hi, I have been assigned the task of buying a couple scales for our color matching department. I would like to get some honest opinions from finishers. What scale would be the best to buy? I am looking for a gram scale that will weigh to the hundredth and allow us to make 5 gallon batches if necessary.
Thank You
3/16/16       #2: Best Scale for Color Matching ...
Jarin Smoker  Member
You might consider talking to an automotive supplier about what scales they use to color match. I buy a lot of mixing cups, tape, masking paper and 3m's PPS system from an automotive supplier, and I have talked to them about scales before. I still haven't coughed up the money for one yet though.
3/16/16       #3: Best Scale for Color Matching ...
PainterDave Member
brand i use
http://www.dataweigh.com/signum/
3/17/16       #4: Best Scale for Color Matching ...
kevin
Fillon tech makes excellent scales.
3/20/16       #5: Best Scale for Color Matching ...
JeffA
Measuring to 1/10th should be just fine. To make 5 gallons, you will need to go as high as 20000 grams. If you make wipe stains, those have more pigments than spray stains so keep that in mind too. A 20000g scale may not have enough capacity. You must also have the scale in an area that no air is moving as it will make the scale inaccurate. Also vibrations from an exhaust fan in a spray booth can make the scale inaccurate.
