spray booth
4/30/16
Ryan Groff Member
I have been spraying my finishes in a self made spray booth, It is framed in with sheet metal sides double doors to bring in material etc. I have a explosion proof fan with a 20 by 20 filter. I keep it about 70-80 degrees when spraying. My question is if I would get a professional made booth, would my finish quality be drastically different. Im sure some of you guys have went from something like i have to a more expensive set up does this warrant the thousands of dollars spent or is it more about cleanliness etc.
4/30/16       #2: spray booth ...
Leo G
As long as it's a clean area and you have good filtration with nice lighting, no, you won't likely see a dramatic increase in your finish quality.
5/1/16       #3: spray booth ...
Alessio
Hi Ryan,
The answer is no. The only thing we ordered for our self-made booth was the fan with explosion-proof motor. We made the filter chambers housing 6 20x20 filters each side, and even had the 24" exhaust ducting custom made and installed ourselves, and installed sealed Led units for lighting. Finish quality is excellent, and my drying area is 12-15ft away and I have zero overspray going behind me. Only difference from a professional booth? A professional booth will be UL Listed and will meet all codes, self-mades booths won't.
You mentioned you have a 20x20 filter.i don't know if you meant you have only 1 but if you are running a 24" fan at full speed, you will need at least 10 20x20 filtered openings to create the right draft.
5/2/16       #4: spray booth ...
al
Alessio,
What brand LED lights did you buy?
Thanks,
Al
5/2/16       #5: spray booth ...
CraigM
You probably won't notice a finish quality difference, but when I set up my booth the insurance company, fire department, and city hall required my booth have an engineers stamp and fire suppression on it to pass inspection.
5/7/16       #6: spray booth ...
Alessio
Al, Brand was techbrite, t8 vapour tight, here in canada i was able to get them at $105 each including 2 bulbs which is a great deal considering the bulbs run $30/each
5/18/16       #7: spray booth ...
scott
I don't want to offend anyone, but the answer is a resounding yes.
Spraying cars is even more of a craft then spraying cabinets, do you know any body shops that have a system similar to yours?
Booths are designed to have 100 cf of air per sq ft of booth face. Spray areas are designed to have a positive pressure to keep contaminants from entering. Spray booths are designed to have filtered air enter them and filters to take all the solids from entering the atmosphere. Spray booths are designed to have temperatures to match the flash temperature of the material you are spraying.
After saying all that, it is possible to get good or decent results with the set up you have, but a professional spray booth makes spraying a breeze.
5/18/16       #8: spray booth ...
A booth is just a fancy metal box, that's it. You can have all the attributes of what you said in a spray room.
I can't see how spraying a car is more difficult then spraying cabinets. Car spraying is usually the outside surface while cabinet spraying incorporates inside 90s, sharp outside corners and lots of nooks and crannies. The main obstacle of a car is it's size.
