ML Cambell
5/17/16
gene Member
Hi all, can anyone give there thoughts on ML's waterbased finishing system..Agualente?? I have been using General Finishes and have had good results, but I have a few clients that what MDF painted panels, I was going to use there water based primer and GF milk paint over top after a 24 hr dry time... or since i was impressed with the ML primer i thought of giving it a go with there pigmented color and there clear.... and can there colors match Ben Moores fan deck, as most every client references there color charts..
thoughts? concerns? thanks in advavce
5/18/16       #2: ML Cambell ...
Pat
I've been spraying MLC waterbased stuff for a dozen years. Agualente is my go-to product for pigmented jobs. I like it better than the GF "milk paint" and it's easier for me to get. My dealer matches BM colors.
5/18/16       #3: ML Cambell ...
B Hand Member
Hello Gene I have sprayed ML Aqualente and SW Kem Aqua, both can be colour matched from BM. In my neck of the woods the SW Kem Aqua is around $20 cheaper, I also find the SW Kem Aqua dries harder then the ML
I find both spray perfect right from the can and level great
I like the ML primer, sands well
Hope this helps
Bruce
5/18/16       #4: ML Cambell ...
gene Member
thanks guys, I found the same results, I put GF milk paint on ML Aqua primer and it looks great, I like the ML primer better then the GF as of right now, and i think the ML blocks stains according to there site..... I will be trying there (ML) pigmented Aqua next job, its cheaper and if it look as good I dont see a problem changing, however I will always default to the GF milk paint for kitchen resprays, it has not failed me so far, new clean work is another story. I welcome any other insight... thanks again
