Flexable coating
5/30/16
Sam Member
In the automotive industry they use an additive to keep the finishes "flexable" on items such as bumpers,etc.. Is there anything that can be done to pre-cat laquer to keep it flexable? I'm thinking we might change to a polyurethane to solve this problem, any ideas?
7/10/16       #2: Flexable coating ...
Yusuke Heller
What problems are you having? I am curious about this question because I often wonder the same thing myself for painted finishes using pigmented CV. Time to time if a cabinet gets lightly bumped the wrong way during install and I hear that crack sound. I immediately start checking all of the joints for that hairline crack. I hate it. Especially on a white finish.
7/12/16       #3: Flexable coating ...
Sam
Yep we have the same issue. If a joint cracks or opens due to climate change in the house, that's bad enough. To make it worse the pigmented pre-cat or post-cat will NOT flex with it and it "pops" loose easily. We use a high quality primer and apply everything according to specs. We are talking about extremely small amounts of movement, but it's just enough. Then we have to hear all the complaints that plain ol' latex doesn't have this issue why does our expensive finish have it? Gets very tough to explain to the homeowner.
10/24/16       #4: Flexable coating ...
francis
try a vinyl sealer or primer under it's more flexible. specialy on hardwood like maple it always crack in the joint. vinyl should help a lot.
