Sticky finish on outdoor tables
8/8/16
David Fryman Member
I have been tasked to refinish a few tables and benches for an outdoor dining area at a local restaurant. The area is covered and has half walls, so the tables are exposed to most elements to some degree. The tables stay sticky to the the touch and it's worse with the heat and humidity. The tables were refinished about a year ago, but not sure what finish was used on them. I was told it was supposed to have been a two part polyurethane. Is there a finish that will not become sticky outdoors? I know there is no bullet proof finish, but surely there is something that will hold up for more than a year. Any other suggestions as to what might be happening are welcome as well as any recommendations. Thanks!
8/9/16       #2: Sticky finish on outdoor tables ...
jimmy cream
is it possible the build up is pollen ? or sap ?
before re-finishing , maybe try wiping with a solvent to see if the residue wipes off .
8/9/16       #3: Sticky finish on outdoor tables ...
Nick
I have seen single component urethanes (both solvent thinned & water borne) do this on resturant & kitchen tables many times. But I have never seen 2k poly or CV do this. I always assumed it was the result of hundreds upon hundreds of detergent cleanings, thousands of plates and glasses wearing down the finish and lots of alcohol & food spilled on it.
I've always cleaned up the gunk with thinner then stripped off what was left.
if 2k poly alone doesn't work, polyester with a 2k poly top coat or penetrating epoxy sealer and 2k poly top coat are the only other longer life finish schedules I can come up with...or table clothes.
8/10/16       #4: Sticky finish on outdoor tables ...
chris
what kind of wood was used to build them?
you will have to strip to bare wood before refinishing.
8/10/16       #5: Sticky finish on outdoor tables ...
I'm always surprised when restaurants put in wood tables. Every time they turn over customers, someone rushes in with disinfectant and scrubs down the table. That's really rough on the finish. Then on this one, you thrown in outside elements. I would not want to be in your shoes when you get the call back!
