air bubbles with Kremlin pump -- 1 --
4/2
Website: http://www.collierscustom.com
We have recently switched to a kremlin eos pump 15 c25 with an xcite gun using 06-132 Tip.
and we are getting lots of air bubbles on the laydown of the coating
We are using an ICA waterbourne lacquer
fluid pressure is 3.5 bar and gun air between 1.5 and 1.8
fluid is thinned to 5% with water and retarder d1072
it seems to be coming right at the lay down of the coat
I have checked the air to the gun and adjusted it between 1 bar and 2 bar with no difference
I have shut off air to the booth and ran a trial to see if its causing issues, this helps a little but the skin over is still happening with some bubbles left.
any help with this set up would be appreciated.
4/2 #2: air bubbles with Kremlin pump ...
I don't do waterborne but it sounds like to much pressure on both sides.
I shoot with 35psi fluid and 16-18psi air.
For primers I boost it to 40psi fluid and go on the high end for the air.
I use an MVX gun with an 06-134 tip.
4/2 #3: air bubbles with Kremlin pump ...
i have had the same issues with the same set up and i'm convinced it is the pump.
my graco pump just went down so i put this eos pump back into action as our clear pump. the bubbles seem to happen/been seen almost immediately. i'd say they are .25" on center, so everywhere. i've experimented with different air and fluid,
different thinners and retards, all to no avail. i've broken down the pump, changed tips, installed a new fluid line, and changed guns without any changes. i simply cannot get it to work with solvent-based poly.
i swapped the eos out for a 20:1 kremlin with older mvx guy and it sprays perfectly. i've also used the same material, just shot it from the eos and from a cat cup gun, and the cup gun stuff looks very nice (bubble city with the eos).
our local kremlin sales place wants to blame the poly guys. not much help there.
4/2 #4: air bubbles with Kremlin pump ...
First off it sounds like your fluid pressure is high. It also sounds like a classic case of WB micro bubbling due to high pressure sheering of the WB product. This is my understanding of that process (please somebody correct me if I'm wrong); WB products have a high level of surfactant (soap) to aid in product flow and lessen surface tension. but when the product is forced through a small opening under pressure some foaming of the product takes place which get distributed in the line then released on your piece where some of the air bubbles flow to the top and pop leaving a crater and some flow to the top and skim over leaving a bubble. The smaller 10:1 & 12:1 pumps were especially prone to this (I have a old 10:1 Graco Falcon and a 12:1 Binks Comet 4/12 and they both micro bubble WB"s) The Kremlin EOS being a bigger pump was suppose to limit this problem. I started using pre-orifice tips and this helped a lot but didn't end the problem so I switched over to spraying WB's through low pressure fluid set-ups (pot/gun, diaphragm pump/gun, gravity gun) and have very good success since then.
That said I have read on this site of people having great success spraying wb's through a pump.
4/3 #5: air bubbles with Kremlin pump ...
I spray Valspar Zenith & MLC aqualente with the Kremlin 10-14 and 09 tip. No micro-bubbles for me.
I also have a CAT gravity Jaguar gun and it sprays all types of Waterbornes with a 1.4 tip perfectly. Even better than the Kremlin. Go figure.
4/3 #6: air bubbles with Kremlin pump ...
Forgot to add, '06' tip seems too small for spraying waterborne.....was this a recommendation from your dealer????
4/3 #7: air bubbles with Kremlin pump ...
The set up we have at the moment was recommended from the dealer of the coatings
they have some pretty good info on the kremlin unit as it has been used hand in hand with the two companies ICA and Kremlin
just seems like I am getting something wrong there
We sprayed a pigmented coating from them and a second job with sealer with great results.
in fact I would say it was the best two finishes I have put on to my cabinets.
4/3 #8: air bubbles with Kremlin pump ...
Dan we don not thin the AOB510 from ICA. the thinning seems to create problems. Just use it straight with or without catalyst. You may have to go mist coat and right away finish coat. Keep distance over 8" from gun to substrate.
4/3 #9: air bubbles with Kremlin pump ...
Also 06 tip is too small. I use an 09-092
4/3 #10: air bubbles with Kremlin pump ...
We have managed to fix our issue today with the help of our rep and have managed to achieve perfect results.
The Tip was recommended as the 06 is meant for the water borne finishes
rather than to much fluid pressure we had to little and were thinning the product.
We switched to spraying straight from the pail no thinning and this completely changed the finish.
After using a 4 stage turbine for two years with lots of issue getting good results this has shown up to be a real game changer for us.
Thanks for the comments and advice.
4/4 #11: air bubbles with Kremlin pump ...
I would examine the final finish 'sheen' very closely and determine if you have not 'sheared' the coatings gloss level with an '06' tip. You would have to do a sample board to verify this potential problem.
Obviously this would be most noticeable at a 40 degree sheen and higher.
4/4 #12: air bubbles with Kremlin pump ...
Hello Robert
can you explain what you mean by shear the gloss level ?
1 --
Buy and Sell Exchanges
Lumber Exchange
Machinery Exchange
Classified Ad Exchange
Forums
Adhesives Forum
Business and Management Forum
Cabinetmaking Forum
CAD Forum
CNC Forum
Professional Finishing Forum
Forestry Forum
Commercial Kiln Drying Forum
Sawing and Drying Forum
Solid Wood Machining Forum
Veneer Forum
WOODnetWORK
Galleries
Project Gallery
Sawmill Gallery
Shop Gallery
Shopbuilt Equipment Gallery
Other Resources
Industry News
Video Library
Repeated Forum Abuse:
Forum Posting Form Guidelines
Your Name
Your Website
E-Mail Address
Subject
Thread Related File Uploads
