Acrylic enamel or tinted CV
4/25/17
Luke Member
Back again tryin to figure out theres finishing questions with spraying. I work for a window company and we also do trim packs and patio doors. Im just getting into the spraying application. At the moment we are using a water based acrylic enamel on our trim. We use CV on our patio doors and windows and i love it. Im using a HVLP at the moment and dont have a problem with the CV but the acrylic is very slow. Way to much thinning and the sheens are terrible. Is a tinted CV the way to go? Im using Lenmars MegaVar. Also would i need to prime b4 using the CV and with what? Thank
4/26/17       #2: Acrylic enamel or tinted CV ...
Shane
Your using a cv on exterior? Let me save you some heart ache and repeat customer business... Stop now and get a reputable tech rep from a coatings company over there to re-vamp your process immediately!
4/26/17       #3: Acrylic enamel or tinted CV ...
Bart
Hopefully you're putting the CV on the interior of the windows.
4/26/17       #4: Acrylic enamel or tinted CV ...
Luke Member
Yes its all on the interior. Finish work.
4/27/17       #5: Acrylic enamel or tinted CV ...
Shane
if your using a catalyzed finish such as Cv you should also use a catalyzed primer........ Makes the entire system much more durable.
4/27/17       #6: Acrylic enamel or tinted CV ...
Luke Member
I just picked up a catalyzed vinyl sealer to go along with the pigmented conversion varnish. Havent used it yet. Is there anything i need to know before spraying it? Do i thin it or run it straight out of the can? How heavy do i lay it on? I have heard u can use BIN.
9/8/20       #7: Acrylic enamel or tinted CV ...
Ronald P Member
Website: https://www.concretefullerton.com/
I an a concrete contractor and deal with patios regularly. I too agree that CV on the interior of the windows is a must..
11/12/21       #8: Acrylic enamel or tinted CV ...
Ryan Leonard
Website: https://www.columbiamocontractor.net
Great! You definitely save my time!
