Ext Enamel on Aluminum
5/9/17
Paul S.  Member
A client wants me to revitalize some old cast aluminum lawn furniture. I'll probably use enamel and clear coat it. I'm brushing it back to clean bare metal. Should that be etched or coated with an adhesion promoter like the Bulldog I use on automotive work?
5/9/17       #2: Ext Enamel on Aluminum ...
Rick Mosher
Here is a great video on painting aluminum airplanes
Painting Aluminum
5/9/17       #3: Ext Enamel on Aluminum ...
What does "brushing it back" mean? I thought heavily oxidized aluminum had to be acid etched for good paint adhesion.
5/10/17       #4: Ext Enamel on Aluminum ...
Paul S.  Member
I'm using wire wheels and Osborn brushes to remove all the old paint. I see from the video that I should etch the surface with phosphoric acid.
5/10/17       #5: Ext Enamel on Aluminum ...
Paul Snyder  Member
Website: finishing.tips
Aluminum is not difficult to paint - using the right primer is critical as well as prepping the surface.
I use Matthews paint a lot and it works great on metal, including aluminum. Their PT filler primer and epoxy primers work great. The catalyzed polyurethane topcoats can be mixed in any color and come in satin and gloss sheen.
Check out the surface preparation guide at the link below.
Surface prep guide and primer selection
