D-Dur vs. M.L.Camp 2KPoly
1/23/18
Steve Juhasz  Member
Website: http://www.centrestreetmillwork.com
We have lots of experience and success with D-Dur (chemcraft) for finishing solid wood entry doors. We also use lots of M.L. Campbell polarion 2K poly for our indoor cabs with great success. My question to you guys is this: Those who have used D-Dur and know how well it works, have you ever tried Polarion on something exposed to the weather? Or another conversion poly which was even better?
1/25/18       #2: D-Dur vs. M.L.Camp 2KPoly ...
Tyler
The reason some 2K's are exterior rated and others are not have to do with the properties of the finish. D-dur is an exterior poly because it is a bit softer than say your polarion, so it does not suffer microfractures to the same degree. This helps prevent moisture/water from getting underneath the finish and causing a total disaster.
