custom NGR stain
2/19/18
mike mcnerney
is it possible to make an NGR light color grey or any of the greys for that matter? What kind of colorants & base would I have to use.
2/19/18       #2: custom NGR stain ...
Brian Member
Just like tinting a wiping stain, black and white pigment, just know that the pigments will obscure the wood somewhat, depending upon the color you are trying to reach. Spray stain bases should only have a few ounces of colorant max per gallon, otherwise they'll settle really fast.
Use a true blue "spray stain base" not a gallon of acetone so you can reduce the blotch or clouds that are usually prevalent with spraying stain.
2/19/18       #3: custom NGR stain ...
mike mcnerney
Brian, The NGR I am using are alcohol based is that what you are reffering to
2/19/18       #4: custom NGR stain ...
chris
check out wd lockwood stains
2/19/18       #5: custom NGR stain ...
Bob Niemeyer  Member
Mike, this is when we need that magical white dye, not a white microlith, but a true transparent dye.
I have seen some really good reactive stains to get good grey tones but sometimes they are not very practical to use.
Many of the european coating suppliers have a white colorant that is very close to a dye and fairly transparent when used thin.
Let us know if you find a a better solution!
2/23/18       #6: custom NGR stain ...
DanShafner Member
There's white and there's white. Zinc white has the least amount of opacity of all the whites, versus titanium white or flake white, which are opaque.
Iridescent white is made with a mica which gives a pearlescent look to the white.
Black dye in small quantities mixed into clear finish yields grayish tones in some situations. If the finish has a lot of flatting paste, building the finish with these two combinations (small amount of black dye + heavily flatted finish) will yeild a grayish haze instead of the white cloudy haze.
When I don't add enough black colorant, dye or pigment, to polyester, I get gray.
