vinyl sealer with CV
7/22/19
mauricio poli Member
Hello !
Is it ok to use vinyl sealer under a CV top coat?
We have a request to closed pore furniture, and looking for the fastest way to close the pores on birch panels.
Costumer is asking to use CV as final coat...
7/22/19       #2: vinyl sealer with CV ...
Jim Clark
That's all I ever used, vinyl sealer then
conversion varnish.
7/22/19       #3: vinyl sealer with CV ...
chris
make sure to catalyze it.
7/22/19       #4: vinyl sealer with CV ...
Kevin Member
The two brands I have used said to catalyze vinyl sealer something like 1% when used under cv. Check with the rep. Or consider something like MLC level sealer for a full fill.
7/22/19       #5: vinyl sealer with CV ...
Much better to ask you finish rep than an open group when we have no idea what brand or product you are using.
7/22/19       #6: vinyl sealer with CV ...
mastercabman
Yes if you are using MLC don't forget to catalyze it with 1%
WVP love it!
7/23/19       #7: vinyl sealer with CV ...
Nick
I use to use this method but SW's vinyl sealer produces quite a bit of formaldehyde when catalyzed and since l mainly use SW's formaldehyde free CV it made no sense to use the vinyl sealer. That said when the job calls for SW's waterwhite CV l go with the sealer.
Of course the products you're using could operate differently but it is something to consider.
7/27/19       #8: vinyl sealer with CV ...
cabinetmaker
Catalyze it.
Definitely ask your supplier..
7/27/19       #9: vinyl sealer with CV ...
Jim Clark
I use Lenmar brand CV and vinyl sealer.
They both use the same catalyst and same
proportion. Keeps it easy.
8/26/19       #10: vinyl sealer with CV ...
Matt Meadows
If you are wanting a product specifically to fill the pores on wood, then vinyl sealer isn't the best choice.
Personally the only thing I'd use in this case is a self-sealing conversion varnish or 2K polyurethane. If you're doing a lot of huge flat stuff, a first coat of polyester clear can also work quicker in one coat than nearly anything else can in 3 coats. You can topcoat polyester with clear CV.
Either way, vinyl sealer is very low solids and doesn't sand worth a crap in most cases. I'd just stick to one can of product if I could, which would be a self-sealing clear CV. They build a lot faster than vinyl and also sand easier. Just don't mistakenly pile on your coats, spray normal 2-3 wet mils, they will cure much faster than "piled on" stuff.
