Water based conversion varnish.
3/24/21
Jeff
I am looking for recommendations for a good clear water based conversion varnish that is also reasonably priced.
I have sprayed solvent based lacquer for years and I am wanting to switch to water based coatings.
The equipment I have to apply it is a Kremlin 30:1 pump, a couple CA technologies 14:1 pumps, pressure pots and a couple Sata gravity cup guns.
I will also look to get into solid color water base as well.
I do have the following dealers in my area,
Richelieu, ICA, sherwin Williams, Lee valley tool has a limited supply of Target coatings, ML Campbell, Becker Acroma and a few others.
I have sprayed some solid water based Sayerlack, it seemed like a nice product but was quite pricey:
The majority of lacquer I have sprayed over the years was Becker Acroma and also a fair bit of ML Campbell.
Thanks for any help.
3/26/21       #2: Water based conversion varnish. ...
Jonathan Mahnken
I hear the sayerlac is the beez kneez, targets cv is pretty good. MLC magnamax h20 performes pretty well but doesnt spray well vertically(sag city)
3/26/21       #3: Water based conversion varnish. ...
I talked to a finisher who had sprayed everything you can think of and has also worked selling a bunch of different finishes after he retired. He said something similar to Jonathan, he said in a water base product Sayerlack is the best hands down.
I bought some and sprayed it and it turned out beautifully. I have not used Target or ML Campbell or any other water based products so can’t really compare.
3/27/21       #4: Water based conversion varnish. ...
Bart
Why do you need WB CV? There are plenty of great poly WB finishes out there. I personally have been using General Finish enduro for years. I've tried their CV and don't see any real benefits for the added costs. Plus if you've been shooting lacquer anything will be an upgrade over what you're using. Most WB CV's are gonna be pricier than WB poly's and more likely safer to use especially if the CV is a 2 part system.
my2cts
cheers Bart
3/28/21       #5: Water based conversion varnish. ...
John Member
I used TC's EM-8000CV + Crosslinker on a dining room table recently. Love how easily it sprayed and flowed out. After the fact, I tested it for resistance to hot water, Windex, and bourbon. After one hour exposure, all three left a white ring and/or ghost ring. In comparison, GF's EnduroVar was unaffected by all three, however, a hot dish will stick to it (and any WB finish I've tested) and pull away some finish. The same tests on Arm-R-Seal showed no effect. I'm still looking for a WB finish with performance on par with an oil based varnish.
John
3/28/21       #6: Water based conversion varnish. ...
Jonathan Mahnken
Chemcraft Aqualux uniclear for cabs, and milesi 2k for tops is one of the best combos for durability. I use the gf poly for anything pigmented because its more "paint like"
3/29/21       #7: Water based conversion varnish. ...
Jeff
Bart,
I guess that is a really good question.
Going forward I would say I am in the same boat as John, I just want to spray water based products that are of great quality and reasonably priced.
I think I have talked to a lot of supplers and have been given the old sales pitch from most of them, so was under the impression that I needed a conversion Varnish.
I appreciate everyone’s feedback.
