Shellac
3/27/24
howard
Website: http://woodcontours.net
Can dewaxed shellac be used as a seal coat under pre/post catalyzed lacquer? Thanks
3/27/24       #2: Shellac ...
JM
Sure it can, but why would you?
3/27/24       #3: Shellac ...
I never take a chance. I use what the manufacturer recommends, and that is usually a vinyl sealer. In cool or humid conditions, shellac can cure rather slowly.
3/31/24       #4: Shellac ...
The MW Studio  Member
Website: themillworkstudio.com
Certainly! Dewaxed shellac can indeed be used as a seal coat under pre/post catalyzed lacquer. In fact, it's a common practice in woodworking to use shellac as a barrier coat before applying other finishes.
Shellac acts as an excellent barrier to prevent any potential compatibility issues between different finishes, and it also helps to seal the wood, providing a smooth and even surface for the subsequent coats of lacquer.
Just make sure that the shellac you're using is dewaxed, as wax can interfere with the adhesion of the lacquer. You can find dewaxed shellac flakes or pre-mixed dewaxed shellac solutions readily available in most woodworking stores.
Before applying the lacquer over the shellac, ensure that the shellac has fully cured and that you've lightly sanded it to provide a good surface for adhesion. Then, proceed with applying your pre/post catalyzed lacquer as usual.
