Furniture Making
Subject: Re: cutting tapered lamp base 90 degrees
9/9/13
Dan
I am making a hardwood lamp from a solid piece of wood with tapered sides. The tapers result in a 1 inch square top and a 3.5 inch square bottom. I need to make a perfect 90 degree on the bottom of the lamp so it sits perfectly flat. I made a simple jig for my band saw miter to account for the tapers and hold the lamp at 90 degrees. A band saw cut however results in blade ridges that need to be sanded. And as soon as I lightly sand the freshly cut base on my mounted belt sander the perfect flatness is lost. My table saw would give a nice smooth cut but the blade does not rise high enough to cut through 3.5 inches in a single pass. I'd appreciate any suggestions you have.
9/9/13       #2: cutting tapered based 90 degrees ...
nicko Member
ten inch miter saw.
9/9/13       #3: cutting tapered lamp base 90 degree ...
mark
Build a sled for the planer. Or bandsaw then hand plane... It takes a little practice.
9/10/13       #4: cutting tapered lamp base 90 degree ...
Keep it simple. Glue a 4" x 10" piece of 60 grit to scrap plywood, clamp it to the bench, and sand the entire base at once with the coarse grit. Once you have even scratch coverage, do the same with a 100 grit, and you have it.
If you have hundreds to do, then use a 12" or larger disc sander and a jig.
In the future, back cut the bottom edge well before assembly so it presents less surface to deal with.
9/10/13       #5: cutting tapered lamp base 90 degree ...
ML
Try using a finer (more teeth per inch) blade with less "tooth set" on your bandsaw. Cut more slowly also. This should yield a much finer cut that can easily be smoothed over with either a sanding block or sandpaper glued to a flat surface (as mentioned by David).
In the past, when making wood lamps - we've usually applied green felt to the bottom of our base after applying our catalyzed finish. No worries about a slightly "rough" cut and the felt is much appreciated for protecting the fine finish on an end table, night table, etc... We punch out a small oval in the center of the felt where we apply our company logo.
9/10/13       #6: cutting tapered lamp base 90 degree ...
Scott Sober  Member
Website: http://www.cymafurnituredesign.com
Why not cut your blank to your desired length so you start square then cut the tapers? Quick simple and easy.
9/10/13       #7: cutting tapered lamp base 90 degree ...
Scott Sober  Member
Meant to indicate cutting with chop saw or table saw for the smooth end cuts.
9/17/13       #8: cutting tapered lamp base 90 degree ...
Dan
Thanks to all of you for your help! A miter saw would work beautifully but I'm not able to purchase one right now. A large sanding disc with a jig would also work but I don't have one of those either. So I think I'll try a finer bandsaw blade, then sand it using a piece of ply and grit clamped to the bench and then finish it off with a piece of felt. A miter saw is definitely joining my shop soon!
