Furniture Making
Subject: Re: Solid ebony glue ups
8/26/20
Kim Thich Member
I need to build a vanity top to look like a surf board. I am mixing wider 8/4 sapele and beech with narrow 3/4” tigers stripe maple. I also want to glue in 1/8” ebony strips (full 2” thick , to be shaped down to 1.5”) here and there. I understand ebony doesn’t glue well. I can’t inlay it because it would be too difficult around the nose (of surf board).I could connect the ebony to adjoining parts with domino(Festool) tenons . Vanity top will be about 5.5’ long x 20” wide by 1.5” thick . It will be tight on back and right wall and nosing exposed on left side.
8/26/20       #2: Solid ebony glue ups ...
Snaglpuss
I haven't found Ebony gluing to be difficult. Have had no problems gluing Ebony guitar head plates to mahogany
necks or Ebony bridges to Spruce tops just using Titebond.
8/27/20       #3: Solid ebony glue ups ...
John Costin
Hey Kim, I hope you're doing well old friend! I think the tenons are not necessary. How about gluing the whole thing up a little over thickness with West System (or other marine) epoxy? Plenty of working time to get things registered as best you can and it will fill any little inconsistencies. Plus, you will never have to worry about the glueline when the top gets wet. I think you know this: not too much clamping pressure with the West System! It needs a little thicker glueline than yellow glue.
Sounds like a cool vanity -- please post pix when it's done!
Be well,
John Costin
Veneer Services Unlimited
vsu@gwi.net
(207)459-7221
Custom Veneered Solutions for the Woodworking Industry
    • Anver Corporation
    • CP Adhesives
