Furniture Making
Subject: Re: Happy springtime neighbors!
3/24/21
heath Member
Thanks for reading.
I've finally had a product idea good enough to justify buying my first lathe but as always I'd like to do it as economically as I can. I'm looking into my local craigslist and fb marketplace listings and thankfully there seem to be enough come through. I'll be looking around in the Cincinnati, Louisville and Lexington, Ky area.
With a budget of around $400 what's the best quality used model I can expect to get into? I'd like to stay away from options that are prone to go bad or are difficult to get serviced, but it needs to be fairly versatile at the same time. Variable speed would be nice. Although I'd like to go with a full size if possible, for now it would just need to turn something 7 dia by ~16 long.
3/24/21       #2: Happy springtime neighbors! ...
heath Member
Actually, just realized I've got $600 store credit at Home Depot so I might as well get one through there as long as it isn't crap. Any opinions about this WEN...
https://www.homedepot.com/p/WEN-6-Amp-14-in-x-20-in-Variable-Speed-Bench
top-Wood-Lathe-34034/306031795
WEN-6-Amp-14-in-x-20-in Variable Speed Benchtop Wood Lathe
3/24/21       #3: Happy springtime neighbors! ...
Wen is about the lowest end out there. I'd never pay retail for anything like that especially in a mini lathe. Mini's are very often bought by someone who gets a fancy for the notion of wood turning then it peters out and they post it on the sites you mention for peanuts because its just collecting dust. You could likley land on a far better quality mini with accessories for far less money used.
Your budget is a bit sketchy in my area for lathes in that the better quality, larger, machines still hold some value and are out of that budget but in my opinion you'd be far better off keeping up your search used for a heavier lathe as opposed to wasting it on a retail purchase like that.
3/24/21       #4: Happy springtime neighbors! ...
heath Member
Thanks for the response Mark. I since talked myself into the Jet 1221VS and thought that's what I'd get until I discovered these duplicating systems. Something like this would be so helpful in my production that I might as well figure one of these in on the whole deal. Problem is most of these duplicator systems mount under the track and require the motor to be either behind or to the left. The Jet has it's motor underneath so I'm not sure I'll be able to get anything to work with it.
Any suggestion for a lathe / duplicator system that's not the $370 one at Rockler?
3/28/21       #5: Happy springtime neighbors! ...
Joel
Check out www.OWWM.org and get yourself some vintage iron!
3/28/21       #6: Happy springtime neighbors! ...
Joel
Also auctions. I was once at one in Lynchburg, VA and one of those big ass powermatic school shop ones sold for $250.
    • CP Adhesives
    • Anver Corporation
