Furniture Making
Locks for touch latch
4/2/13
Jonathan Cunningham
I have built a chest of drawers that doesn't have any drawer pulls. The slides are Blum under-mount tip-on, which is a built in touch latch. When you push the front of the drawer, it moves in and then springs out. The client now wants locks on these drawers. Because of the in and out action, I can't find a lock that will work. I don't want any surface hardware on the drawers, so I'm thinking a magnetic lock would work the best. I have Stealth locks, but I can't make that work with the touch latch action. Any ideas?
4/3/13       #2: Locks for touch latch ...
Kilgore Trout Member
A gang lock will mount on the side of the case and lock all the drawers on that side of the case. No hardware will show on the drawer fronts.
However, in most scenarios, the drawer may be able to be pushed in, activating the ejection spring, but the lock may prevent it from ejecting/opening. This will run the drawer out of cycle and cause problems for your customer, causing your phone to ring.
Set up the gang lock so that drawer cannot be pushed in when locked - only when unlocked. This will prevent getting out of cycle.
