Steel table legs with timber feet -- 0 --
8/24
Website: http://www.thecabinetmaker.ie
Hi. I'm making a dining room table. The timber top will be connected to a steel frame. The legs are 11/2" steel pipe. The legs end in timber 'feet' of approx 16" height. My problem is how to secure the pipe to the foot. I discussed this with welder, who'll make the frame. Best we came up with is weld a lag bolt to end of pipe, pre drill timber and screw on(with gripfill for extra bite. Have a look at picture of scale model. Welder will link the steel with cross bars. Still worried about racking and wobbling though. I'd be grateful for your input and suggestions. Much appreciated! Thank you, Henk
View higher quality, full size image (3648 X 2736)
8/25 #2: Steel table legs with timber feet ...
There is a reason no one has ever built a table like this before.
8/25 #3: Steel table legs with timber feet ...
Bore through the logs.
Weld a foot plate on the bottom of the legs.
Rout out the bottom of the logs for the foot plate, so the steel is well off the floor.
Pass the legs through the log, and screw them in from the bottom.
Use a larger diameter pipe to slip over the exposed part of the leg; let it go all the way to the top, or at least far enough away that you can weld it to the leg without scorching the log.
Now the log is trapped, and solid. Have fun.
8/26 #4: Steel table legs with timber feet ...
Bore out the logs, epoxy the steel pipe inside it. If you bore deep enough, the epoxy will just be there to keep it on the pipe if they lift the table. I think the 1 1/2" pipe will really look undersized if the table is of much size. 2" or 3" will keep the scale right so it doesn't look like it is on tooth picks.
8/28 #5: Steel table legs with timber feet ...
have your welder weld on a hollow square to the inside of the pipe. then fit a tenon into it and epoxy or screw it in place.
Chaim
0 --
Buy and Sell Exchanges
Lumber Exchange
Machinery Exchange
Classified Ad Exchange
Forums
Adhesives Forum
Business and Management Forum
Cabinetmaking Forum
CAD Forum
CNC Forum
Professional Finishing Forum
Forestry Forum
Commercial Kiln Drying Forum
Sawing and Drying Forum
Solid Wood Machining Forum
Veneer Forum
WOODnetWORK
Galleries
Project Gallery
Sawmill Gallery
Shop Gallery
Shopbuilt Equipment Gallery
Other Resources
Industry News
Video Library
Repeated Forum Abuse:
Forum Posting Form Guidelines
Your Name
Your Website
E-Mail Address
Subject
Thread Related File Uploads
