Furniture Making
Balanced laminate?
9/4/13
mark
I'm working with a spec that calls for double thicknesses of sheet goods to form (overly) thick shelves. I've always stayed away from even number flat laminates, with the expectation that they would bow. What do y'all say? Would you lay up two thicknesses of the same plywood in a vac bag with thightbond?
9/5/13       #2: Balanced laminate? ...
Joe Doherty
Mark,
4 years ago I laminated 3/4" to 3/4" domestic core plywood using Titebond III in a vacuum bag and the shelf parts have stayed flat. The parts were 11" and 14" wide with lengths up to 70". I also laminated 3/4" to 1/2" to 1/4" cocobolo to get 1.5" thickness and these parts have also stayed flat. I stored the parts in my shop for quite some time them assembled them and moved the finished shelves into an air conditioned office and still no movement.
Joe in New Orleans
9/5/13       #3: Balanced laminate? ...
mark
Thanks, Joe.
9/25/13       #4: Balanced laminate? ...
Dave
Balance is what matters. Balance is when both sides of the panel center plane are the same. With a single sheet of plywood, an odd number of plys is balanced. With two sheets of plywood (same thickness/orientation), and even number of plys is balanced.
Using two thicknesses of the same material has an advantage in that you can face-to-face the bowed (or cupped) side of the material and get something flatter than you started with. After getting some warped 3/4" MDF, I'm thinking two layers of 3/8" might be good insurance when building slab doors.
