Furniture Making
Table leg joint strength
12/1/13
Michael Sanders Member
Website: http://www.michaelsanderswoodworks.com
An architect wants me to build a small conference table for his office. It will finish at 84" long, 33" wide, and 30" high. The material is 12/4 cypress, reclaimed from an old train depot, and has been sitting in a dry warehouse for at least 10 years. He wants to dovetail the legs into the top, giving a clean parsons table look. I don't think this is going to have enough lateral stability and will eventually break. Any bracing between the legs would completely restrict the movement of the top. Check out the images. Anyone have a good idea? Thanks!
CONFERENCE_TABLE__JOINT.pdf
View higher quality, full size image (1024 X 739)
12/1/13       #2: Table leg joint strength ...
P. Hanes
I have used the joint you have depicted on several tables. It worked well and was quite strong. I tend to be like you and visualize someone dragging the table across a room on the carpet. There really is no way to protect yourself against the poor judgement of others. I believe it is a strong enough joint for any reasonable use. People can figure out a way to break almost anything. It is not idiot proof, neither is your finish.
12/1/13       #3: Table leg joint strength ...
mark
I've also had good luck with a similar joint: pegged through tenon, not a dovetail. The table's about 6 years old, but made in cherry.
12/2/13       #4: Table leg joint strength ...
I see no problem with the joint as you have it planned. Cypress is a bit soft, and that would be my only concern.
Make a test joint and try to destroy it. I bet you will find it as strong as a 3" apron with a haunched 1/2" x 2-1/2" x 3" tenon in a 4" leg.
12/2/13       #5: Table leg joint strength ...
JeffM
Would you trust a mortise and tenon in this application? That's pretty much a through mortise and tenon without an apron.
I don't see much of a problem.
12/4/13       #6: Table leg joint strength ...
Thanks for your input guys. Because the top is laminated to show the edge grain, I can make the outer strips with the legs joined to them, and then glue those to the top. This will give me a chance to see how strong the joint is before I commit and lose the chance to mortise in a cross brace between the legs. I hope you all are right, and that is not necessary. I will post a pic when the table is complete.
2/14/14       #7: Table leg joint strength ...
Delivered the table yesterday. The dovetail was more than adequate and the table was as sturdy as any traditional style. I also posted a picture of the console I made to go with it. I showed the client this thread and he was impressed I sought out industry advice. Thanks to all that contributed!
View higher quality, full size image (2927 X 2196)
View higher quality, full size image (1154 X 1847)
View higher quality, full size image (3000 X 4000)
3/21/23       #8: Table leg joint strength ...
TMVHM
Website: https://tmvhandyman.wixsite.com/tmvhm
Thank you for this great idea of fixing the legs to the table top. I very much like the clean look. I wanted a thinner table top so I was afraid your solution wasn't going to be strong enough. I added some beams under the table ends to mount the legs with a bridle joint. It is really solid.
If you would like to see how I did it, please check my blog post.
View higher quality, full size image (3982 X 1825)
https://tmvhandyman.wixsite.com/tmvhm/post/a-solid-14-person-table-design-and-build
    • CP Adhesives
    • Anver Corporation
