Furniture Making
wide belt sander problem
3/29/14
David Klenk Member
Website: http://davidjklenk.com
Hi, I have a Timesaver Speedsander wide belt sander. It has a 37 inch wide belt. when I feed narrow pieces of stock through the sander the pieces in the center of the belt are not getting enough friction from the pinch rollers to pull them past the belt without slipping. I have checked the distance between the pinch roller and the belt roller to be sure they are lower than the belt roller and parrellel to it. The problem seems to be that the pinch rollers flex when stock is fed at the sides of the belt. This causes the pinch rollers to flex upward in the middle, so the stock in the middle of the belt does not get as much force pushing down on it. Is there something I can wrap around the center section of the pinch rollers to create the downward force needed to solve this problem?
3/29/14       #2: wide belt sander problem ...
Adam West  Member
Take the platen out of the machine. With the machine completely off, put a piece of stock in the machine and close it carefully until the sanding belt on the drum is very lightly touching the top of the part. Open the machine .050" and check that the rollers have light pressure or just barely touching.
I have set up hundreds of machines and several of the speed sanders and have not noticed roller flexing to be an issue. I would suggest not putting through more than two pieces at a time so you don't end up high centering and losing hold down on one or more of the pieces.
3/31/14       #3: wide belt sander problem ...
David Klenk Member
Hi Adam, thank you for your advice. I did what you said to do and ran about one hundred narrow strips of wood through the sander without one slipping back. My thought is that it was not properly set at the factory. I have had other problems with this machine. It seems to be well designed but it wasn't adjusted before it was shipped. So I had to learn how to adjust and maintain it through trial and error. Your experience and skill would have saved me over a dozen belts if I had you set the machine up when it arrived from Timesaver. Thank you again.
3/31/14       #4: wide belt sander problem ...
Adam West  Member
Glad to help. Good little machines when they behave.
