Furniture Making
milling process
5/12/14
Dan
I'm interested in general rules of thumb that one can use when making decisions about sizing wood pieces for rough milling. For instance, if I'm making two chairs is it best to rough mill all eight chair legs--and then let them sit for a day of adjustment--or would it be adequate to mill down to the size of four boards and wait until final milling takes place to cutout all eight? The essential question is, how small does a work piece have to be rough milled for the wood to be able to adjust to workshop climate prior to final milling?
5/13/14       #2: milling process ...
Rich C.
Lots of variables. Wood species, thickness, trust in kiln operator, moisture content check when material arrived, how long it's been in the shop, time of year, etc. Thick chair legs? I would mill all the parts and make the chairs. How long is it going to take to make two chairs anyway? It's not like making tall narrow stock doors, it's a chair.
5/13/14       #3: milling process ...
Dan
Thanks for your WoodWeb reply Rich. The chair leg description was just an example. I'm going to be making some items in small volume soon and so I'm trying to make the process as efficient as possible. Less milling, fewer saw cuts, etc. would save time. I'm not looking to compromise quality though so I will take your advice as a good rule to follow.
5/14/14       #4: milling process ...
mark
Since you see a necessity in acclimating the stock, then the answer is to cut the pieces as close to the final shape as possible while allowing for the stock's movement during acclimation. The amount of extra is divined through experience, and as Rich suggests above, perhaps some experience might even teach you how to avoid this step altogether.
5/20/14       #5: milling process ...
correy smith
As Rich and Mark said, you need to know you wood your dealing with and how it was dried. You should rough mill as close as you can or might go two rounds of acclimating. Even a 2x2x20" long piece can spring significantly in relation to joinery. So it's always best err to the side of caution.
Your shop conditions will also dictate how much wood moves after milling. If you have a shop that's unheated wood will move daily as the rh changes from night to peak temps( and low rh) in the day.
