Furniture Making
edge gluing Hard Maple Tabletops problem
10/12/15
Troy Member
Website: http://continentalhardwood.com
we have edge glued 8/4 solid Hard White Maple to make some Table tops, but are having problems with the finished product.
glue lines are great with no de-lamination. but now the grain in the middle of the staves are tearing apart. what are we doing wrong.
the finished product is 1-1/2" x 48" x 120"
and the component parts are 6"wide x 120"long.
10/13/15       #2: edge gluing Hard Maple Tabletops pr ...
You didn't screw it down hard with no allowance for wood movement did you? Any cross grain cleats or other methods that won't let the wood move? Might need a picture.
10/13/15       #3: edge gluing Hard Maple Tabletops pr ...
Troy Member
nothing screwed or glued down, still raw tops.
10/13/15       #4: edge gluing Hard Maple Tabletops pr ...
Joel
If it's happening in the middle of the board as pictured you have a wood problem not a joinery problem.
10/13/15       #5: edge gluing Hard Maple Tabletops pr ...
Geoff
I agree with Joel. The wood might have been dried too fast and developed internal stress cracks. Somewhere along the way the wood gained moister, the wood swelled and the cracks closed up. Now it is drying out again and cracking.
It would be interesting to know what the end of the boards looked like in the rough. If what should be a pretty true rectangle is badly deformed it is a sign of not being dried properly.
10/15/15       #6: edge gluing Hard Maple Tabletops pr ...
Gene Wengert-WoodDoc
I also agree that the issue is wood quality. If thick hard maple is dried to rapidly, it gets these fine hairline cracks that can increase in size in the final product...the wood will shrink a bit more in use. So, it also appears that the wood was too wet for your use.
10/15/15       #7: edge gluing Hard Maple Tabletops pr ...
Troy Member
we put a moisture meter on the wood prior to lamination. 4 readings,
6.2%, 7.1%, 7.3%, 7.9%
10/15/15       #8: edge gluing Hard Maple Tabletops pr ...
Gene Wengert-Wood Doc
If the wood is indeed this dry (assuming you used a good moisture meter, calibrated for species), then the cracks of this size are 100% cracks from the wood prior to your assembly and then the RE-OPENED later (and were not created later).
10/15/15       #9: edge gluing Hard Maple Tabletops pr ...
Geoff
One way to tell if internal cracking might be a problem is to look at the cross section of the lumber in the rough. if it is badly deformed (not a rectangle) it was most likely dried too fast and could have internal cracks.
I remember getting some 10/4 qtr. sawn white oak that the cross section was shaped like an hour glass. there were no visible cracks on the surface of the wood. When I cut into them, the core was honeycombed with cracks.
10/15/15       #10: edge gluing Hard Maple Tabletops pr ...
One way to check for existing checks, splits and honeycomb is to cut wafers. The process is illustrated on page 102 of DRYING HARDWOOD LUMBER.
10/15/15       #11: edge gluing Hard Maple Tabletops pr ...
Troy Member
Thank you for all of the information.
