Furniture Making
Upholstered curved chair backs
9/26/16
We are looking at making some arm and side chairs that have an upholstered seat and back, wood arms and legs. The curved back of the chair is upholstered front and back.
This is something new for us and I had originally thought of laying up veneer and vacuum bagging the backs over the form but then wondered if other would go about this with two layers of bending ply?
Im having trouble locating what I would consider to be cost effective construction grade veneer to lay up.
Sorry for the simple question but any input is appreciated.
9/27/16       #2: Upholstered curved chair backs ...
Glen
Chairs are tricky to make well. We have the same chairmaker for the last 32 years and he cuts all the parts from solid wood. If I understand you are looking to make a traditional dining chair with a curve on the back. We use the bandsaw and pin router to make the curves and use webbing to create the back surface for foam and fabric.
9/27/16       #3: Upholstered curved chair backs ...
Glen,
Thanks for the info. The bandsawn solids is what we would normally do. These are not dining chairs but what type of chair they are isnt really relevant. These are not the backs or even the type of chair but we are shooting for something in this direction:
http://www.livinghomefurniture.com/wp-content/uploads/2015/04/upholstery-tear-down
As I mentioned, in the chairs we are planning the entire back is upholstered.
9/27/16       #4: Upholstered curved chair backs ...
Glen
Link goes to LH but no image. If it is a formed plywood back we do a jig and glue up 1/8" then veneer over it all or add a solid top if it is a rounded top. The more radical Italian curved chairs I won't do
9/27/16       #5: Upholstered curved chair backs ...
We will try this.
View larger image
9/27/16       #6: Upholstered curved chair backs ...
Glen
We would build a jig and glue up 3/8" bending ply then veneer it all.
9/27/16       #7: Upholstered curved chair backs ...
Glen
Actually i would not veneer it as it is fully upholstered.
9/27/16       #8: Upholstered curved chair backs ...
Thanks Glen,
We took the long way around to it but that was my original question. Lay it up with veneers or two layers of 3/8BP... lots of good information though.
9/29/16       #9: Upholstered curved chair backs ...
Keith Newton
Well, if you just use two layers of bending ply, you only have two thin veneers running horizontally where you really need to connect for strength.
I would add a thick face veneer to both sides of one layer.
As for the actual bagging, I would make a form where I bent the whole sheet at full size, then cut the parts from the big cylinderical shaped part.
Rather than having to make a substantial plug to form around inside of the bag, I like to use a big envelope that contains the laminates after the epoxy is rolled on, then bend the whole bag around the form which is outside the bag, and can be made very easily out of cheap ply or sheet goods. Then it only has to be strong enough to support against the springbuck of the sum of parts, which is not much, and only needs hand pressure to hold against the form, while another person clamps some 2x4s long enough to hang off the ends. Once the vacuum is pulled, they aren't even needed, since the pressure on both sides of the bag is so great it will hold the shape even without the form, so long as you don't loose the vacuum.
Bending ply comes in 4x8 and 8x4, with the face veneer running opposite on each option. Shops that edge glue door skins can supply you with single ply faces whatever size you require.
That is what I would do, but I don't' do big volumes.
5/9/17       #10: Upholstered curved chair backs ...
MarkSindone  Member
Website: http://supercheapselfstorage.com.au/facilities/syd...
Thanks Keith for the comprehensive input. I did have a thought about the thin ply of veneers. They could be too weak for durability and you would really want that in an arm chair. I guess the key is to use thicker ply layers or fix a few pieces together if there is a need to.
