Furniture Making
find the right stud
1/8/17
marci Member
Website: http://modifyfurniture.com
I need a 1/4 20 steel knob with a two inch long stud. There is a particular knob that I want. How do I permanently attach my own stud?
1/9/17       #2: find the right stud ...
JM
Drill, tap, then epoxy or loctite the 1/4-20 stud in
1/9/17       #3: find the right stud ...
Pete D Member
I use a stud welder, very fast and repeatable with a template. If you're doing any sort of quantity I'd sub it out to a machine shop to drill/tap and follow JM's advice. Probably easier to locate a machine shop than someone with a stud welder. If you want to tap them yourself make sure you get a tap for blind holes.
