Furniture Making
Arches
1/28/20
Garen Pletzer Member
What is the best way to make arches. They're big bends and thick wood so bending is out of the question. Do you miter them or edge glue? the biggest one is a 32" radius and 1.5" thick x 1.5" wide.
1/28/20       #2: Arches ...
bill
This thread goes into some detail. Good Place to start.
Bent lamination.
1/28/20       #3: Arches ...
Dave Sochar Member
You don't state the degrees of arc or a chord length, but this is an easy one.
Bent laminations would be my first choice. Use wide piece of stock - 3" or more, and 1-5/8" or more in thickness. Mark the end of your stock with a pyramid so you can put the plies back in order after ripping. Rip out 1/8" plies, slowly and carefully, with a good blade. Avoid stops/burning. If you are exact, then you will need 12 plies. Put them back in their growth order and make your form.
Strike your radius - 32" - and chord length plus on a piece of 3/4" plywood. Fasten 2" high blocks 1/2" behind your stricken line, then add two layers of 2" wide, 1/4" thick MDF or plywood. You do not need fancy bending wood for this (or most) radii.
You can add a top ply at the 1/4" line if you would like to stiffen things. Be sure to have it the same width/length as the blocks, so you can rune clamps over the top of it with no problems.
We use epoxy when we want a rigid glue line. Plastic resin is nice but it needs 75 degrees or higher to set.
Above is "Bent lamination". Bill refers to "Brick Laid curves". Both are sound methods. Brick laid eliminates springback and and make a curve of almost any size. Bent lamination will have some springback but can be grain consistent if carved or cut into.
1/28/20       #4: Arches ...
Would you be against running the grain in one direction instead of the brick laying. I think their would be more wood movement. I thought of that brick laying but was just wondering if it would look better if the grain rain all in one direction. Stain will be dark so that helps.
1/29/20       #5: Arches ...
Mitered segments, floating tenons at the joints, then rough out on bandsaw, finally pattern shaper run against a template. You don't give much for details about paint or stain grade. Is it structural?
1/29/20       #6: Arches ...
They are cabinets. free standing screwed to the wall. other parts are the top of a few benches have a 1" tall by 2" wide half circle top. floating shelves with radius corners that i figure i can 45 and cut it out. Some will be paint grade others a dark stain. Rift cut white oak.
1/30/20       #7: Arches ...
Dave Sochar Member
The brick laid curved head jambs we make all get a facing of veneer to clean up the brick laid face. This makes for a clean look that will not telegraph the brick laid parts behind it. Just be sure to use/make something thicker than 0.040" or the butt joints can show in time.
    • CP Adhesives
    • Anver Corporation
