Subject: Re: butt joint
butt joint
8/15/13
Wes Jones Member
Is there any type of fastener that can be used where 2 - 3/4" panels butt together to create a 90 degree corner, eg. a column wrap, so that no fastener is used on the face such as nails or screws?
8/15/13       #2: butt joint ...
mark
Glue.
8/15/13       #3: butt joint ...
Nick
Here's a couple options for you;
-glue and tape
-biscuits and clamps
-dominos and clamps
-dowels and clamps
-a spline and tape/clamps
-rabbet and glue and tape/clamps
-"L" cleat nailed/screwed from the back
-glue and 23 gauge pins
-knock-down fittings from the back
There's probably a few more yet...
8/16/13       #4: butt joint ...
mastercabman
there is a router bit you can get to do a joint like that
It's called a lock miter.
Bit
8/27/13       #5: butt joint ...
chris
"Lockdowel", or "Invis" by Lamello, "Rafix", and as Nick suggests
Lockdowel
9/21/13       #6: butt joint ...
JAKE
Ok. How about using hand cut blind mitered dovetails.
Do you have a MORE specific application or requirements that are unique and somehow challenging, preventing you from arriving at an obvious solution?
Otherwise, I am wondering why anybody would need to ask how to join two 90 degree parts with a stupid butt joint. Middle school shop class is that way.
1/12/15       #7: butt joint ...
Bob Carreiro Member
Use a lock miter joint. No need to cover edge.
