Subject: Re: Need a quick KD hardware solution for freestanding wall panels
1/17/14
Matt
Please see attached. These panels were originally screwed together in the field which worked but the work is slow.
I need something that allows quick assembly like z clips but that doesn't allow sliding or lateral movement and is forgiving(the panels sometime move a bit with the seasons so tight 'line-up' tolerances are a no-go. I'm almost thing eye hooks on one panel and 'L' hooks on the mate would work sort of like hinge pins ....
the panels are 8' tall and have lower shelves and closet rods at upper portions
Other solutions are much appreciated.
Thans,
Matt
7.19.13_NY_BOOTH_2.pdf
1/18/14       #2: Need a quick KD hardware solution f ...
Matt,
Here is the assembly of a show booth that we used for several years. The panels ( about 40" X 96") were joined to each other with slotted aluminum columns.
Each panel had 2 cam fittings (top & bottom) that would lock into the aluminum columns. Where 2 panels came together without a column, an aluminum bar was inserted into a slot in each panel then locked in place with a cam fitting.
The booth walls were very fast to assemble and take down. Also, the size and configuration of the booth could be easily changed by adding or removing panels.
Unfortunately, I don't know right off hand who makes this system but I thought it might give you some ideas. If you are interested, I could research a little further.
View higher quality, full size image (2780 X 722)
1/18/14       #3: Need a quick KD hardware solution f ...
Matt
Thanks Dennis. That's exactly the kind of functionality I need. But the look is wrong. My booth is made of pallets and has a very rustic 'feel' to it.
Also, if this helps get some more options, the panels don't need to lock together rigidly and tightly. The small return walls and corner bump outs keep everything freestanding.
I was thinking this might work also..
1/18/14       #4: Need a quick KD hardware solution f ...
I would check with Titus or Hafele for a fitting. Both have a huge selection for almost any application.
Good Luck...
Titus Link
1/22/14       #5: Need a quick KD hardware solution f ...
Matt
Dennis,
Thanks for the links. I forgot about cam locks. May be the ticket.
Matt
1/24/14       #6: Need a quick KD hardware solution f ...
tracy kling
try norse roto locks they are made for trade show booths
also southco fasteners make a cam lock for trade show booths
1/24/14       #8: Need a quick KD hardware solution f ...
Matt
Oh now Tracy, can you feel the warm vibes of awesomeness I am sending your way right now?? Those are EXACTLY what I'm looking for!!
Pros that I can see....surface mount and they don't require any new material between the panels so my booth won't grow.
Thanks! :)
