Subject: Re: Legrand Under Cabinet Lighting
8/5/14
John Member
I'm currently designing a kitchen that will have Legrand undercab lighting/power. First time for me and this system. I do F.F. style cabs and typically have 1 1/4 " from upper base to lower edge of frame. The Legrand system wants 4" and is supposed to attach to the underside of the case. That's fine except the cab opening is 2 1/2" higher off the floor. I could simply drop the case but then there's only 15 1/2" from counter to upper.
Anyone dealt with this? What did you do? Thanks, John
8/26/14       #2: Legrand Under Cabinet Lighting ...
Josh Koschak Member
Convince whoever to use different lighting, is that an option?
4" requirement underneath the cabinet floor seems to be a high waste of space.
11/19/14       #3: Legrand Under Cabinet Lighting ...
Dave Member
We've had very good luck with Seagull Lighting.
http://www.seagulllighting.com/
