Subject: Re: Fitting a very thick slab?
6/25/16
Website: http://nwcabinet.com
I need to cut a 4"+ thick end grain butcher block 42" x 96" walnut slab to fit. half way around two posts and then cut out for a sink. Cut has to be clean, precise and tight. We built and installed all the cabinetry and are being asked to do this by the contractor who has given us alot of work so I can't say no.
Any ideas on how to approach this???
6/26/16       #2: Fitting a very thick slab? ...
That is a tough one.
I think I would turn it upside down and cut a rabbet into it first. Then do the usual with a skill saw and jig saw and belt sander.
Because of the end grain an angle grinder might do better?
6/26/16       #3: Fitting a very thick slab? ...
mike Member
1.Unless I'm missing something just set up a straight edge and cut it with a circular saw as deep as it will go then grab your hand saw (i still own one) and finish the cut.
2. Set up the straight edge again and use a deep straight bit, flip it over and use a deep bit with a bearing on each half.
6/27/16       #4: Fitting a very thick slab? ...
Pete D Member
I would clamp or screw a straight edge/guide to the bottom where the cutouts are and plunge a router bit to get an edge reference in the slab. Hog out the cutouts with jig saw ~1/8" inside reference cut from router then use a stout, long spiral router bit with top bearing against initial plunge cut. Flip slab over and use a spiral bit with bottom bearing against initial cuts to clean up top half.
6/29/16       #5: Fitting a very thick slab? ...
Angle grinder and a Sawzall?
6/29/16       #6: Fitting a very thick slab? ...
Thank you guys. As it turns out the cut out only had to be 1" deep by 8" wide on two ends.
So We jigged it up and plowed it out from the side with a shank sided following bearing. Took quite awhile.
I used a skill saw and sawzall combo to cut out for the sink.
It all came out perfect. I think I incorporated some of everyone's suggestions.
