LED strip lights used under counter
7/27/12
Randy Member
Website: http://www.dovetailconstruct.com
Has anyone used the adhesive backed LED strip lights for under counter lighting? Looking at the new Wurth LED's and can't tell if they put out enough light . Also how does the adhesive tape hold up?
7/29/12       #3: LED strip lights used under counter ...
Ted Nehlsen
I replaced the "puck" style xeon lights in a kitchen with LED strips from WAC. New lights give a more even light, are brighter, whiter, and don't give off heat. Customer could not be happier. Wife saw the results of the job and guess what. I now have them in my house.
7/29/12       #4: LED strip lights used under counter ...
Randy Member
Thanks. Did you use the 24 or 12 diode per ft?
7/30/12       #5: LED strip lights used under counter ...
Derrek
Website: http://closetdr.com
Hafela has a great line of LED strip lights that we install regularly. We have had no issues with them, they are nice and bright and have several options for switching. Price is much more affordable than any previous LED lighting we used.
9/5/12       #6: LED strip lights used under counter ...
Dewalt DW744XRS Table Saw Review Geek Member
Website: http://www.tablesawreviewsgeek.com/reviews/dewalt-...
LED has come such a long way, it is the only option for me at this point. Low power consumption, long bulb life, and plenty of light. The amount of light was the main issue with LEDs back in the day, but that is no longer the case. Pretty much any brand will do as long as it isn't some china knock off .
9/17/12       #7: LED strip lights used under counter ...
Dan Member
I agree, that's the reasons why I only go for LED lights now.
LED Strip Lighting
2/7/13       #8: LED strip lights used under counter ...
Nick Member
I second that, I've begun to only use LED lights now.
Decoled
7/11/13       #11: LED strip lights used under counter ...
masonfox Member
Website: http://www.ledbeinc.com
i think the adhesive tape of LED strip light not good enough,you can consider use LED profiles for LED strips.
8/14/14       #13: LED strip lights used under counter ...
alanwang
Website: http://www.szledcolor.com
i advice you use to apa102,apa104 led strip to make it , can make amazing effect
APA102 APA104 LED STRIP
