homemade filler
3/18/16
Tony
I am looking for some advice about making a filler for some small gaps in a bamboo floor. Not a job of mine, but a colleague who has asked my advice. He needs a binder (?) to mix some of the sawdust with to fill a few small "imperfections" around a fireplace hearth. I don't think a conventional wood filler would be durable enough. He is thinking an epoxy, but it would take more than just an off-the shelf size. Any suggestions would be appreciated. Thanks
3/18/16       #2: homemade filler ...
Do an experiment by putting sawdust into joint then squirting cynoacrylate and then misting with water. No guarantee but worth a try.
Cheaper water is the catalyst
3/18/16       #3: homemade filler ...
Most gaps are caused by wood movement from seasonal changes. Professional fillers are formulated to be somewhat flexible. Some home brew filler is not going to have that same performance.
3/21/16       #4: homemade filler ...
Tony
Thanks for the replies. The gaps weren't caused by movement, just poor scribing. lol
9/6/16       #5: homemade filler ...
Bill  Member
Website: canadianacabinets.com
We often made fillers from exotic wood sawdust and basic pva white glue. It dries clear and is a bit flexible
Cheers
