beam saw cut
4/27/16
Anthony Member
hello all hope your having a great day
i would like to ask if any one can tell me how to calculate how many melamine board can a pressure beam saw cut in an hour knowing that i am looking at "HOLZ-HER TECTRA 6120 classic" :
Saw Blade Protrusion up to 82 mm
Sawing Unit: up to 11 kW
5/2/16       #2: beam saw cut ...
No way to tell from here!
The blade has to protrude above the panel at least 4mm or the top will likely chip. So with a new blade, 4 sheets of 19mm (3/4".) As the blade wears,less. Part size 4x4' or 3x3"? Unless you have a lot of repetitive patterns you won't be able to stack cut every load. What means of handling do you have?
