Prefinished butt joints and joinery for large bench
7/12/17
Mike Member
I'm fabricating and installing what needs to be a prefinished bench. I do all finishing in the shop and arrive with the materials for installation and the job is done and ready to use when I leave. It's just the way I do things as a one stop shop.
Currently, I am building a large L shaped bench. It consists of a lamination of plywood and MDF for the show / painted face. the plywood gives the necessary support underneath and MDF the superior paint capabilities.I am building it as a very long component and will half lap the construct at the L corner. It will result in a butt joint at the corner. I'm building in shop so that will be quite well fitting so I'm not worried about that. I'm joining along the long side 2 pieces of MDF, which I am pretty good at. Being prefinished and in two pieces both by transportation and shop capabilities, that butt joint will not be finished to perfection. After the joint is finished, the front edge will be trimmed out with a roundover 1x3 trim, also prefinished. Trimming on site will allow me to make small adjustments due to any site conditions that may exist, at least I think that's a good idea. Perhaps I'm making this way too complicated. How would you do it? Would you use a v groove by a double chamfer at the butt joint and along the edges where the trim will be? Thanks in advance.
7/12/17       #2: Prefinished butt joints and joinery ...
MarkB Member
Is there going to be adhesive or some other means to seal the raw MDF at the joint? Id be worried about edge swell at the joint if the MDF is going to be field.dressed on assembly.
7/12/17       #3: Prefinished butt joints and joinery ...
Plywood and MDF do not have the same expansion characteristics. Something is going to give if there is not great climate control. If I remember correctly, MDF moves about the same as some hardwood.
7/16/17       #4: Prefinished butt joints and joinery ...
"Perhaps I'm making this way too complicated. "
There you go
