9" stain grade baseboard installation
8/13/17
Mark Member
I've been asked to quote the installation of 9" x 3/4" stain grade select alder base throughout a 12,000 + sq ft home.
The height of the 1 piece molding combined with it being prefinished, stain grade and exasperated by going in post flooring (scribing to wood and stone flooring) has me scratching my head a bit with a time / $ factor for installation.
Part of me is thinking that if they want me to do it they'll have to pony up for a simple hourly rate. I can't control the quality of everyone from the framers to flooring crews ahead of me..
Any words of wisdom or divine revelations?
8/14/17       #2: 9" stain grade baseboard insta ...
Not all sales are a good sale. The think that also stands out to me is Alder. It dents if you look at it sideways. Every time you drive a nail you have an opportunity to dent it. Prefinished?
8/14/17       #3: 9" stain grade baseboard insta ...
Bruce H
Figurer what you think it will take and double it. Twice if it doesn't seem like enough. Then go look for an easier job.
8/14/17       #4: 9" stain grade baseboard insta ...
Mark
Listen to the part of you that says hourly- your post strikes me as coming from some one who won't kill the clock.
Other than that, tell them you'll have to see everything done before you can give them a solid price- and if it gets to that (doubt it will, sorry) check every where with a straight edge and a string so you know what your up against.
I hate wide one piece base- if it has any kind of profile on one edge it often doesn't cope straight because the stuff usually cups. They say it sames time, but usually not for the trim guy.
I've actually told contractors I would give a better price if I could rip the profile off and re-apply it separately. A couple have let me.
8/15/17       #5: 9" stain grade baseboard insta ...
Paul Miller
I would not walk away from a 12,000 sq ft house. Do you think these people are looking for a budget job? Talk with the contractor and be sure you know what they are looking for. There will be an Architect for sure. I am going to take a wild guess and say these people have money and it is not their first home.
Like the comment above, estimate what it would take you do to it, double that number and add a healthy profit.
If you get the job, it may lead to more work in the house and these are the jobs where you will make some good money. I would not do a job like this as time and materials. You can make a lot more bidding it.
Also, if you get it, put only a couple of guys on the job, your very best at the skill level and also customer relations.
If the owner, architect and builder gain confidence in your ability, they will give you work throughout the house. Money is not the issue here and there is no reason anyone should loose money on a 12,000 sq ft home.
8/15/17       #6: 9" stain grade baseboard insta ...
nicko
can you use a shoe mold?
nicko
8/20/17       #7: 9" stain grade baseboard insta ...
The builder is charging 20%. The Architect is charging 5-10%. The Designer is charging less than 5%.
Those guys want you to charge as much as possible. The customer wants it done asap. They don't really care if it costs another $50k. The builder would be more concerned about the quality and the guys getting it done in a reasonable amount of time. I would guarantee to have all of my guys work overtime(50hrs/week) at whatever rate you feel comfortable. If he balks go double on a liberal estimate.
9/17/17       #8: 9" stain grade baseboard insta ...
Pinetree
I agree with Paul bid this job and don't do t&m. Figure every piece you will have to scribe and make sure you add a good profit. Hopefully the GC hasen't blown the budget yet .
6/29/18       #9: 9" stain grade baseboard insta ...
Jkinteriors Member
Ballpark price would be 3.50 - 5.00 per lf depending on how cut up the house is and how profiled the base is.
Cheers
7/28/18       #10: 9" stain grade baseboard insta ...
Alder is a terrible choice for base! 9" wide, one piece will have all sorts of issues. I hope the back-out cut is enough to offset the non-flat nature of it. Finding that much 9" was probably a struggle for the mill shop. If they glued for width maybe it will be a little more stable. Copes will be a struggle. If you price it three times as high as you think it should be, you shouldn't loose a lot of $.
