digital levels
1/5/19
guy knight
2 years ago i bought the stabila i love it i no longer need to strain my eyes to see the bubble last year i bought the 48" one love it also then at black friday i came across there 72" one i now use all three just set the two long ones one in front one in back and the short one across no more need to move them makes leveling so easy money well spent
1/5/19       #2: digital levels ...
I use a laser, when the top is all red you're level.
1/6/19       #3: digital levels ...
guy knight
just had to do it now you have me thinking LOL
1/6/19       #4: digital levels ...
I still use levels. But the laser is the main thing I use for cabinets. Even if the sides are a bit out for whatever reasons the tops are dead on for the counters.
It'd be nice to have 2 lasers when you are installing Euro cabinets, front and side. Then you know the box is square, level and plumb.
1/7/19       #5: digital levels ...
Harold
Lasers here too, vanities get level.
1/7/19       #6: digital levels ...
I can get a more accurate result with a bubble. Most digital are only one decimal point. If the level is just off level, but not to the place of rolling another decimal, you can be off 0.1 degrees. 0.1 degrees over 4' is 5/64"
1/7/19       #7: digital levels ...
Yup, 2 digit accuracy is required if you want to compete against a bubble level.
1/9/19       #8: digital levels ...
You are correct in describing the static accuracy of the lasers vs bubble levels.
However, the bubble levels are used dynamically in succession. 78” levels marked by pencil, held up by hand extended down a wall across to the other wall.
The lasers are fixed in place. The accuracy is accurate to the spec. You are kidding yourself if moving a bubble level around a room is more accurate.
We use a combination of laser & bubble. My favourite new toy is a cheap little Lufkin that shoots a vertical spot on a ceiling. No more plumb bob...
2/4/19       #9: digital levels ...
Chris
laser, shim kick, then dbl check with levels.
2/5/19       #10: digital levels ...
Eric Member
Website: http://handymanaustin.net
I use the laser ones almost exclusively, they just seem to be a little more reliable.
2/6/19       #11: digital levels ...
Buddy  Member
Website: http://www.wakeforestfence.com
I've wanted to make the jump to the laser for a while. Good to know they are used by others.
4/4/20       #12: digital levels ...
rick Member
I've had a laser for a while now but I still use levels for the majority of my work. I find them to be quicker then lasers for most casework. The laser works best for me when laying out long runs of crown, chair rail, etc. However, I think that it comes down to personal preference. Whatever you're comfortable with is the way to go.
3/19/21       #13: digital levels ...
Clarence
Website: https://www.wakeforestfencing.com/
We use bubble levels when installing our fence posts.
9/10/21       #14: digital levels ...
Red Deer lawn care
Website: http://absnowremovalandlawncare
Digital levels are only needed for fine-tuning installations. Not required in this field of work.
6/28/23       #15: digital levels ...
Buddy Pratt
Been using bubble levels forever for building fences. Have been curious if the digital levels will work in bright sunlight.
    • American Vision Cabinets
    • Cabinet Pro
    • WalzCraft
    • Steve H. Wall Lumber Co.
    • CP Adhesives
    • INNERGY
    • Palmetto Cabinet Doors
