job site generators
10/27/16
harold Morantz
WE have started working on some large new home renovations and will need a potrable generator for installs. not more than two lines needed, for table saw,drills,jigsaw,etc and a small compressor.
Any recommendations? we will have two crews on site,one for kitchen and other for bath vanities on two seperate floors. Thanks, Harold.
10/28/16       #2: job site generators ...
Hen Bob Member
Honda
10/30/16       #3: job site generators ...
Richard
I have a small Yamaha which can run on gas or propane. Its quiet and economical to run
10/30/16       #4: job site generators ...
harold Morantz
What size generators are you using? Alot of our time is spent levelling, joining cabinets and attaching uppers to wall with cordless drills. These do need recharging, but can often run most of the day before needing a charge. The power is needed more for jig saw, hole saw, small bosh portable saw or chop saw at end of job for fillers and toe kicks.
10/30/16       #5: job site generators ...
Hen Bob Member
I know Honda makes some small lightweight ones, 1000kw , 1500kw. Very quiet . I belive Yamaha dose as well. We have larger Honda
11/28/16       #6: job site generators ...
Dan Sadler Member
Be careful not to go too small or the voltage will drop and could damage or ruin motors. Last time I used a generator I fried an electric motor. I'd like to think I've learned a lesson, we'll see
11/29/16       #7: job site generators ...
Harold
Website: http://www.morantzcabinets.com
I got the small Honda. 42lbs and so quiet you can carry on a conversation next to it. Used it for two weeks on and off and it is great for cabinet installs. Powered small Bosch tablecsaw, pancake compressed, small power tools and chargers. Very happy with it and other trades on site were very impressed.
12/5/16       #8: job site generators ...
ron bergley  Member
Website: http://www.qualitycustominteriors.com
Lots of good generators out there. I'd look for a used one personally. Many brands are excellent including Yamaha and Honda.
New is over priced IMO.
Ron
Quality Custom Interiors
12/13/16       #9: job site generators ...
Jay Miller Member
Harold,
Couple other thoughts, depends on the type of jobsites you are at and the type of work you find yourself doing most...
-Large inverter, possibly add a 1500-2000w inverter running off of a couple true deep cycle batteries (look at boat and rv forums for best practices in this area), this all stays in your truck and you run a cord.
-The above might go hand in hand with a small generator or good solar panels....?
-Invest in more cordless tools. Anything I hold in my hand on on job is cordless for what we do (Cabinet install, small amount of trim with the cabinets, not general standing and running trim). Jig saws, oscillating (Fein) saws etc. Festool even has a cordless track saw, not tried it yet but it is on my list.
Just some thoughts from a different direction.
2/19/17       #10: job site generators ...
harold Morantz
post script to my original quote: We have been using the Honda portable for several months and it is a great machine. Barely uses any gaz,lightweight,quiet and reliable. Harold.
11/9/18       #11: job site generators ...
Joseph Nelms Member
Honda.
3/5/20       #12: job site generators ...
James Member
I use the Westinghouse WH2200iXLT generator. It's really quiet, easy to carry around and can power several devices simultaneously. You can pay attention to this gen as well.
    • American Vision Cabinets
    • Cabinet Pro
    • WalzCraft
    • Steve H. Wall Lumber Co.
    • CP Adhesives
    • INNERGY
    • Palmetto Cabinet Doors
