kitchen island installation
12/28/13
Norseman Member
I am installing a kitchen island with 3cm granite, no plywood backing needed. The island is large enough (5x7') so cabinetry is not supporting some portions of the island. Looking for advice on maximum span (internal and perimeter) for framing members where cabinets are not present. Maximum unsupported overhang is 10". Is there a UBC on this?
12/28/13       #2: kitchen island installation ...
Leo G  Member
Website: http://www.lrgwood.com
Generally 10" is about all you want to do for an unsupported overhang. I'd still put some corbels under it. 8" I would let hang free.
12/28/13       #3: kitchen island installation ...
Bob
I suggest you talk with the granite counter top fabricator and ask for his recommendations. I know from past experience that some granite is a lot more fragile than others. My granite guy has allowed 14" of overhang on some jobs with no worry but he has had me put braces on others that was only 8".
The area on the inside of the cabinet is not as critical as the overhang. One brace going front to back with a support going down to the floor would be enough. However, if one will do it, two will do it better. Better safe than sorry.
12/30/13       #4: kitchen island installation ...
ML
Pay close attention to just what is "supporting" on your base cabinet build. I've seen framed cabinets with no center partitions that go from the floor to the top of the cabinet used for islands resulting in broken cabinets. With the toekick recessed back 3", all the weight is supported only by however the frame (and carcase sides/back) are attached to the plywood floor. Those 1/8" dado's with hotmelt glue are just not up to this task! Not implying this is you fabricate your cabinets, just saying...
Full height partitions are the cat's meow! :-)
I agree with Bob on consulting with your stone fabricator - he's best qualified to guide you in the optimum direction for what and where supports are needed for your particular application.
12/30/13       #5: kitchen island installation ...
JDean Member
Website: http://josephzambarano.com
To keep a real clean look we will use a piece of plate steel cantilevered from the cabinets into the knee space to support the counter top without blocking the visual or usable space.
3/1/14       #6: kitchen island installation ...
Chris
I was under the impression steel plates are the norm. Seems to me they are in 90% of the jobs I see. They are usually 1/2" x 3" x 1/3-2/3 rule of thumb cantilever distance. Ask the stone fabricator what he wants.
2/27/21       #7: kitchen island installation ...
Kevin K Member
I have seen a lot of projects where they either use a steel support post on the interior of the kitchen island or on the exterior if the granite countertop overhangs.
Stainless Steel Table Legs
    • CP Adhesives
    • INNERGY
    • WalzCraft
    • Cabinet Pro
    • American Vision Cabinets
    • Palmetto Cabinet Doors
    • Steve H. Wall Lumber Co.
