Corner rounding 3mm PVC
8/15/12
Arvin
Does any one have any insight on corner rounding. I want to use 1/8" round over bit but bearing seems to large as it would be better to have bit cut into ajacent banding by a hair. Current bit does not cut deep enough and leaves a edge. I bid on Tangent corner rounding unit and did not get it. Does any know what they use for tooling. I have done this several times in last 10 years and have never came up wiyh perfect solution other than buy a new edgebander
8/17/12       #2: Corner rounding 3mm PVC ...
Bruce H
there is no bearing on the bottom of the bit for a machne like this. it can be adjusted any way you like. as for doing it by hand, it's gonna requite a bit of clean up after routing.
8/24/12       #3: Corner rounding 3mm PVC ...
Chris
I've done quite a bit of this by hand as banders I have used in the past where never dialed in as well as they shoulda been.
I used a regular 1/8" roundover bit (any brand) and clean up last 1/32 of not yet flush banding with a sharp chisel. My only heads up is that this was commercial work and the occasional chatter marks from router didn't matter. Try a slower feed rate I would guess
9/4/12       #4: Corner rounding 3mm PVC ...
Rich  Member
Take a look at Betterley's PVC trim router or there file-rite trimmer.
www.betterleytools.com
