PL Seams
3/23/13
Larry Member
What is the best way to join plastic laminate countertops? This always seams to be a problem.
3/23/13       #2: PL Seams ...
Overlap the laminate on a jig for splicing laminate, made of MDF. See sketch
Pull the PB with the draw bolts with no glue.
Glue up one side of the top. Laminate the other side of the top, with sticks and pull the laminate tight to the piece of laminate that is stuck down and stick the first few inches, then pull the sticks on the rest of the top.
router_jig_2.pdf
3/23/13       #3: PL Seams ...
Larry Member
You are suggesting to assemble the two tops with the drawbolts(one already with laminate) and then lay up the second piece of laminate to join the first where the joint will coincide?
3/23/13       #4: PL Seams ...
yes
3/23/13       #5: PL Seams ...
Larry Member
I never considered doing it that way. It seems to always be at the focus of attention to the client. The best I could come up with is to joint the top with a router and straight edge. Maybe a Penske? Ive been using a mdf straight edge run over a jointer. With the laminate already installed, one of the countertops would have to be cut upside down to not chip the p-lam front edge. This cuts the two edges straight, hopefully, then the joint would be good. The two substrate joints might be cut before the p-lam is glued, then use a trimmer to cut the p-lam edge following the straight cut. Maybe.
3/24/13       #6: PL Seams ...
I have seen what you describe done. It works. Especially when the top is postformed.
You understand that the router jig I describe makes the laminate fit together perfectly?
If you have a good sliding table saw this works as well.
Or a countertop saw but they don't always produce a good joint.
3/24/13       #7: PL Seams ...
Larry Member
Yes. It makes a mirror cut. It is probably more ideal since it covers imperfections in routing and the straight edge.
3/29/13       #8: PL Seams ...
BOb
we space the p-lam slightly less distance apart then the diameter of the router we intend to use.
For example, using a 3/8 diameter router bit we would place the laminate approx 5/16" apart.
Then using a small router run the router along this "seam" cutting a small amount off of each edge.
We create a jig that captures the router on each side.
Hard to explain, but router base runs along a straight edge on both sides of the router.
Clamp everything so that nothing will move.
Place the jig over the 2 lam edges and run the router through cutting both edges.
Using this method, even a small wobble will be reflected in the other piece of lam and will fit together perfectly.
Also when you glue the lam on the intended surface, try and create a very slight bubble in the sheet so that when you press it down the seam tightens up.
This is tricky but really does work when you get the hang of it.
Having said all of this we use our CNC router now because it creates perfectly straight edges very quickly.
3/29/13       #9: PL Seams ...
gene
Just about what I did however I just usually overlapped the laminate pieces an inch or two, marked where the seam was going to be and had a straight edge jig that I clamped down on top of the two pieces at the distance the edge of the 1/8 cutter was from the edge of the router and ran the router down the straight edge. Glued usually the one on the left down first and like bob said made a "bubble". I used 1/8 steel welding rods for holding the laminate off the particle board. brought the edges of the seam together, removed the rods and stuck the right side except about 3 rods right up by the cut/seam and then "rolled" with my fingers/palms the bubble into the left side.
