wood edge on solid surface top
5/6/13
mark Member
Have a customer who wants a wood edge on a solid surface top, anyone tried this? My biggest concern is adhesion between the wood and the solid surface.
5/11/13       #3: wood edge on solid surface top ...
Carl Hopkins Member
Without knowing the exact nature of what the look is.
One thought I had is could you make the wood portion be a wide trim that is connected to the box and the solid surface floats over it. No real solid connection between the two just routed and sanded to appear as if they are.
Or use silicone back away from the edge so as to allow some flex. The solid surface requires a substrate anyway.
Just a thought.
5/13/13       #4: wood edge on solid surface top ...
Greg B  Member
Website: http://www.countertoptrends.com
Mark,
We have done this in the past with no problems. Use same color of seam fill that you would use for solid surface seam. No adhesion problems and when sanded blends
in very well. Best of luck,
6/10/13       #5: wood edge on solid surface top ...
Ed Strahota  Member
Website: http://www.blackbros.com
Greg/Mark, I wonder if using a plate joiner is your best bet to keep the expansion/contraction in check? Any thoughts Greg?
6/12/13       #6: wood edge on solid surface top ...
Greg B  Member
Ed,
If your solid surface material is smooth on the back it would not be a bad thing to do but I think you will find it is a lot of extra work for the benefit. the only expansion and contraction will be the wood and I believe you will find over time it to be minimal.
Best of luck,
3/1/14       #7: wood edge on solid surface top ...
Brian
Greg... When you say seam filler are you referring to the two part color matched adhesive used to join the solid surface butt joints in fabricating and do you use it as an adhesive to attach the wood edge. Thanks in advance.
Brian
3/4/14       #8: wood edge on solid surface top ...
Greg B  Member
Brian,
Yes that would be correct.
Thanks, Greg B
