Corian to steel adhesive?
8/26/13
Greg
I made 2 tops, using 1/4" Corian, which covered a 3/4" square tube steel frame. The size is 24" x 48" x 1". I siliconed the tops to the frames, but the adhesive failed. The tops are used outdoors in Vegas, so they are subject to high temperatures. Any ideas as to what type of adhesive I could try? Thanks,
Greg
8/26/13       #2: Corian to steel adhesive? ...
anon
Your application is getting into territory that is starting to fall outside of dupont's fabrication guidelines. That being said I have used corian outdoors in all sorts of extreme conditions, for non conventional applications such as signage.
Make sure to allow for movement of the corian, and substrate. It does not take much expansion/contraction to crack a brittle material.
You did use silicone glue right? Not just silicone caulk. Only other thing I would be open to trying (at your own risk) might be Lexel caulk since it seems to stick to anything. Go easy with it.
Another thought may be to use the brass threaded inserts with machine screws. Holes in the substrate should be slightly larger. Tighten the screws by hand, and back off a little little when snug so they are just slightly loose.
8/29/13       #3: Corian to steel adhesive? ...
Bruce H
I'd try some 3M 5200, any marine store should have it.
8/29/13       #4: Corian to steel adhesive? ...
Greg
Thanks guys. I just saw the 3M 5200 earlier today. I think I'll give that a try. I really don't want to put a hole in it.
8/29/13       #5: Corian to steel adhesive? ...
Bruce H
good stuff but does have a seven day cure time...
