substrates
7/10/14
marci
can you laminate onto plastic, if so what type?
7/13/14       #2: substrates ...
Eugene Member
What are you planning to go over...you "can" laminate laminate onto laminate but...can pull back off of some
7/15/14       #3: substrates ...
Vijay kumar kunchum  Member
By using polyurethane adhesive you can paste laminate to most of the substrates that we use in wood working. To be able to spread the adhesive better, pick up p.u.adhesive which has around 60% to 70% solids. Spread glue on both sides. Allow a little time for the surface to become tacky. Then press both the surfaces together. Put another sheet over the surface and put some weights over it. P.u. adhesives require good pressure for proper adhesion. P.U. Adhesives are moisture curing adhesives.
I have pasted hpl over Wood polymer composites.
