Laminate Adhesives?
1/7/15
Mike Member
Website: http://Minnicksupply.com
In our shop we use regular contact adhesive applied with a brush or roller. Majority of our work is post formed countertops with an occasional self edged project. With a large self laid up project in our future, and cold winter air preventing open windows for ventilation, it seems like time to look into new water based adhesives. What products are you other posters having god success with, also any to avoid?
1/9/15       #2: Laminate Adhesives? ...
Nick
Hey Mike, I don't use water based contact, but I do know the two large postforming companies in my area use wilsonart.
My advice to you would be to ask your countertop supplier what they use, I'm assuming you're mainly using it for finished ends and they would have already found what works best for them and their substrates.
1/9/15       #3: Laminate Adhesives? ...
Mike Member
Had not thought about PF supplier, will try that. Actually interested in doing self laid up tops. For the end caps and edges on post form we will probably stick with solvent based. Thanks.
5/29/15       #4: Laminate Adhesives? ...
hardwoodfloor  Member
Website: http://hardwoodfloorsrefinished.com/
A range of contact adhesives for bonding small and large surfaces. Ideal for use on bonding veneers of timber and laminated plastics and areas where clamping or pressing facilities are either not available or difficult to use.
