Plam delaminating issues -- 2 --
7/20
We are having continuing issues with plam delaminating from jobs after installs. We were spraying Wisonart canister glue and just switched to Sta Put SP 80. We have a well heat shop and AC in the summer. We noticed that it seems that the substrates are shrinking more then the laminate. Edges are cleaned up nice but at the time of delaminating the laminate is hanging over. We pinch roller when ever possible but this does not seem to matter. We had both reps from Wilsonart and Sta Put here to show exactly how to use their products. We still have issues. All the work is in commercial sites. Field temperature conditions vary as well. Is any one else have these problems as well? Any ideas what is going on?
7/21 #2: Plam delaminating issues ...
Hey Walt, I'm curious does this happen on a variety of substrates, or just MDF?
I recently had to switch, I was using premier adhesives in the canister and the supplier has switched to Formica which I will never buy again. So now I was thinking of trying wilsonart.
7/21 #3: Plam delaminating issues ...
We have this problem with all substrates.
Melamine, MDF, Flake. the glue sticks in the shop and then fails after install. We do notice shrinking in the substrates. We trim the laminate nice then it overhangs when the delaminating occurs. It is all commercial work and site humidity varies greatly. We were using Wilsonart glue. I just changed to Sta Put SP80 to see if there is any difference in bonding. The bond between the to glue surfaces is what is letting loose. It sticks to both surfaces. I have been doing this for more than 35 years. The shop has all well seasoned mechanics. I never seen this happen so often.
7/21 #4: Plam delaminating issues ...
It sounds like your problem is more related to expansion/contraction if you're noticing a difference on your previous edges.
I don't trust contact on MDF or melamine, either one I will do when I have to but always roughed up with the belt sander with 40 grit first.
You might want to try laying up your panels in a press with pva if you can.
7/23 #5: Plam delaminating issues ...
Website: http://hardwoodfloorsrefinished.com/
Delamination failure may be detected in the material by its sound solid composite has bright sound, while delaminated part sounds dull, reinforced concrete sounds solid, whereas delaminated concrete will have a light drum-like sound when exposed to a dragged chain pulled across its surface.
7/29 #6: Plam delaminating issues ...
I didn't have very good luck with canister glue. Try one job using spray grade and a pressure pot and see if there is a difference.
8/4 #7: Plam delaminating issues ...
The ongoing problem with solvent and water base contact cement is the solid content or neoprene . We still spray solvent base Wilson art 800. With no problems we are also a post forming shop . We use the same glue for laminate cabinets. With the canister systems there all pretty much the same unstable garbage! Look at the gun passages I bet they are small for the low solid glue? I usually get 2-3 mfg reps trying to push there product so we run both the 800 and whatever they have at the same time. Once I pull it out of the machine I grab there sample and it delaminates without much effort then I ask them to try and pull apart the core with the w/a 800...... Then I get the our glue is best for flat work bs. as they are walking out I ask again why would I change ? That's the last time I see them. Bottom line no laminate shift or de laminating . We have been in the laminate business for 50 years! Ouality materials
= quality products =$$$$
2 --
Buy and Sell Exchanges
Lumber Exchange
Machinery Exchange
Classified Ad Exchange
Forums
Adhesives Forum
Business and Management Forum
Cabinetmaking Forum
CAD Forum
CNC Forum
Professional Finishing Forum
Forestry Forum
Commercial Kiln Drying Forum
Sawing and Drying Forum
Solid Wood Machining Forum
Veneer Forum
WOODnetWORK
Galleries
Project Gallery
Sawmill Gallery
Shop Gallery
Shopbuilt Equipment Gallery
Other Resources
Industry News
Video Library
Repeated Forum Abuse:
Forum Posting Form Guidelines
Your Name
Your Website
E-Mail Address
Subject
Thread Related File Uploads
