Large veneered doors substrate and max. size
10/11/15
Robert Member
We have a closet job coming up where we will be veneering the walnut doors in the shop. My first question is, how large would you reasonably make a door and expect it to stay flat? These will be full overlay Euro hinged doors, going for consistent 3/32" reveals. With our current design, I'm hoping for a door that is 28"W x 90"H, but the width could come down if need be.
Second question - what would be an ideal substrate, and would cross banding make a big difference? Nearby shops have been using lumber core (basswood?) with an MDF face with good results, but I don't have much experience with it, and am worried about movement on such a large door. I've had issues with both MDF and birch multiply as a substrate so I'm wondering what others prefer. We'll be gluing a 1/2" solid edge all around prior to laminating with Unibond. I'm hoping for an approx. 1" thick door in the end. Ability to stay flat is my main concern. Thanks for your help!
10/13/15       #2: Large veneered doors substrate and ...
John S  Member
Robert,
The size doesn't really matter, it's the construction that matters. It needs to be a balanced construction, which normally for a door would be one face, one crossband, the core, another crossband and the back, in that order.
As far as the core material, I would strongly advise you stay away from stave core (Basswood staves glued together) and go with a particleboard core.
10/13/15       #3: Large veneered doors substrate and ...
Robert Member
Thanks John! What would you say the benefits of a particle board core would be over a good quality MDF like ranger board or Medex? If using particle board, is there a certain grade or density that is best?
10/13/15       #4: Large veneered doors substrate and ...
John S  Member
Hi Robert,
Actually, I like MDF too, but you indicated you have had issues with it, so I left it out. I have no problem using MDF core in a door application. In a case where you are lumber banding the core, it would be my preference.
If I went with particleboard core I would ask for "industrial grade" with a density of around 40-42 pounds per cubic foot. That should suffice for that application.
10/14/15       #5: Large veneered doors substrate and ...
Robert Member
Hey John, I think the issue with the MDF was my own fault in not cross banding. It makes perfect sense that a door would warp if there is no cross grain to counteract the face veneer.
One last question - does thickness matter, especially as doors get larger? i.e. for a 28"x90" door could I start with 3/4" MDF, ending up with an approx. 7/8" T door? Or would it be advisable to bump it up to 1"?
10/14/15       #6: Large veneered doors substrate and ...
John S  Member
Hi Robert,
Yes, you definitely need to crossband that door, especially to prevent "telegraphing" of the hardwood stiles and rails.
You should be okay starting with 3/4" MDF. The only caution I would have is to make sure that after gluing the lumber bands on and sanding it flush on both sides that you don't get too thin a door for what your customer is looking for. As long as you use a balanced construction, stability shouldn't be a major problem.
10/15/15       #7: Large veneered doors substrate and ...
Robert Member
Excellent, thanks very much for your help John.
10/15/15       #8: Large veneered doors substrate and ...
John S  Member
You're welcome!
