Solid Surface Seam Color Match
10/11/16
Steve Member
I just seamed together two pieces of Arctic White solid surface. The white glue that I used turned dark.
I ran a shallow cut with a track saw and filled it with solid surface but now there are two thin dark seams, one on each side, in this otherwise pure white top.
I considered routing shallow 1/2" groove, dado, and inlaying a piece of the arctic white material. I thought I'd see if anyone has any other suggestions before I do that.
This glue stays white when used to fill holes in the epoxy resin sinks. Not sure why it turned dark in the sheet,
Thank you in advance.
Steve
10/13/16       #2: Solid Surface Seam Color Match ...
Dave Edgerton  Member
what brand of adhesive and did you wipe everything down with alcohol before seaming?
10/13/16       #3: Solid Surface Seam Color Match ...
Steve Member
Hello,
Thanks for your response.
LG Hi-Macs. Yes, I wiped it all down with denatured alcohol.
I went ahead and cut grooves and put material in. It worked fine and looks good. I was just looking for other options.
I hate working with Arctic White. It shows everything.
9/8/20       #5: Solid Surface Seam Color Match ...
DOUGLAS P CONTI Member
White has its issues. First off if you are working with artic white get rid of all pencils. Pencil marks are very hard to remove completely, No rub them down with alcohol and think that you got it all but there is still some residual graphite left on the top. Next you need fresh gloves, and lots and lots of fresh white rags. Any dirt or contaminates will be drawn into the white seam fill, and darken the joint. I just had three sheets of bone delivered a few days ago, and the driver did not tarp and he got into a rain storm. There was all kind of sh*t on those sheets, it took two guys 2 hours just to get them clean enough to start fabricating. Just remember on white and light color seems you can not be clean enough, change your rags often, make sure the last "clean" on a seam is with a fresh rag, and there is no dirt on your hands. Try this when you have time, make a 20 inch seam in a piece of white and put a pencil mark 2 inches from the seam and about 8 inches long. Wipe the pencil mark down (clean it) and then make the seam as you normally would. You will find that where the pencil mark was the seam will be a little bit darker as compared to the rest of the seam.
    • Impact Search and Placement
    • ECabinet Systems
    • Better Vacuum Cups, Inc.
    • Doucet Machineries Inc.
    • Forestry.com
