SCM Basic 1 Keeps Stopping
6/25/19
Jake Member
I have an older SCM Basic 1 edgebander that keeps stopping halfway through a panel - the roller is spinning and the banding is going on fine, but just about as soon as the leading end is cut, the rollers stop and the machine needs to be reset. The manual is all but useless...any advice?
6/25/19       #2: SCM Basic 1 Keeps Stopping ...
Jim Member
Make sure the height is set right.
Mine will stop if if is putting to much pressure on the panel.
6/25/19       #3: SCM Basic 1 Keeps Stopping ...
Jon Member
It could be a bad magnetic contactor, or it could have dirt/dust in it. I had contactors that would release unexpectedly. Maybe the jarring of front trim unit is enough to make it let loose.
Most complicated machines such as edgebanders have one main contactor and multiple contactors after the main one for various motors.
7/3/19       #4: SCM Basic 1 Keeps Stopping ...
larry
Late on replying. The machine usually cuts off automatically if a motor is drawing too much amperage. This is to protect the motors. By reset, you mean there is a relay that is turning off and has to be reset?
4/6/20       #5: SCM Basic 1 Keeps Stopping ...
JURAN
Chech the air pressure... bigger pipe inlet. or put it more pressure on main air inlet pressure regulator. I had the same problem
